crap petrol = crap boost...???
andypotts1981
55
I had to goto one of these pay at pump petrol stations yesterday as my local garage was shut so had to use 95 ron at asda.
Today my boost is all over the place - sometimes holding 14psi and other times not even holding 10.
Can this be put down to crap fuel?
Gravesie-363
LCR 225
Aug 4, 2009
353
Darlington
Certainly can! When i bought mine i was given a morrisons fuel voucher for £25, so shot that in, and it had a horrible flat spot in second gear.
Soon as i filled up with V Power again, it was fine . . . No idea what boost it was at, as i dont a gauge!
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
Yep, lower octane petrol is less resistant to detonation. It will therefore detonate too early in the cylinder causing the engine to "knock". The 1.8t engine has knock sensors which will see this and back of your boost and timing appropriate to prevent damage to the engine.
DOLBY
2,934
98
North of London
www.facebook.com
godber225r...i guarantee someone will be along in a minute to tell you that what your talking is rubbish...
i agree with you though, any performance car of any type should be using 99 fuel......too many people buy good cars with there heads in there a£$es..and refuse to fork out an extra £5 (over the course of a tank) for the good stuff, just because they are living in cookoo land and refuse to believe the 99 petrol is better for the engine...
Aug 7, 2009
1,395
Manchester U.K
Mine is calibrating its self on 99ron V power so i guess it will be alot better than the 95 ron i tried it on. Going to keep this in now as its calibrating its self as the battery been off for 2 months so its learning its parameters on 99 ron and hopefully will give good results. Just putting £5 in of v power wont show any effect as it will change its habbits throughout its drive cylcles, same as if 2 people drive, it can take a wile to re-adapt to how you drive The standard ECU is mapped for 98 ron as said in the fuel cap but there able to run on 95 aswell if 98 isnt available, the APR map with programmes has a 98 & 95 ron setting so you can change if you put 95 ron in, quite handy :)
Aug 7, 2009
1,395
Manchester U.K
who said anything about putting £5 in bud?
was just saying an extra £5 over the course of a tank extra you pay for the good stuff
Wasnt aiming it at you, was only saying for people, will take 1 - 2 tanks of jungle juice to get the benifit if you run it on diffrent fuel, also try to stick to one fuel station, i.e shell, bp etc, as mine is learning its self on shell it will stay on it now and when she goes on rolling road next month compleatly standard il soon see any benifits (apart from fact its de-catted) but everything else will be standard, then il put uprated diverter on and airfilter, and see what she puts out then.
DOLBY
2,934
98
North of London
www.facebook.com
55 litre tank and the fuel round my way is around 7-8p more.....but yeh it really is pennies and i think redline magazine done a test and the engine was clean compared to mega clogging up with the 95 shite
Aug 7, 2009
1,395
Manchester U.K
always best to stick to the busiest fuel station also, as the fuel is constantly getting reoplaced..
Fuel doesnt go stale instantly, but after a month will start to slowly loose its goodness, one i use is one of busyest stations round here, i know what you mean though, if its been sat there for a month and hardly anyone uses it can start to loost freshness. Proper jungle juice from shell these days, used to be 97 and didnt really rate it. BP ultimate is just robbery and sainsburys is 97, Tesco is 99 but dont have it at tesco near me.
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
Dont forget better MPG too... so i doubt theres much difference even if it seems more expensive.
OFI
350
Salisbury
I always noticed when mine was filled with 95 RON. I wouldn't notice for a little while then i'd wonder why the car didn't feel quite right. Then i'd have to think back to the last fill up and remember I went for the cheap stuff.
As above given that the difference if a couple of quid a tank I just use V-Power now.
Will running 95 RON on a remapped car damage it? Or will it feel even worse than people are finding on non mapped cars?
godber225r
T15 PJG
Sep 6, 2008
893
Whiteley, Hampshire
Agree with you totally bret.
ive been using v-power in my lcr for 18 months now and since using it have seen much better performance over 95 and miles better MPG so it must of cleaned it out internally.
I think you need to always use it to see a difference not just the odd tank here and there as a treat for it wont do much.
and the extra fiver in the tank at every fill up is definatly worth it i never care how much it costs to fill up anyway!!
I drive it till the light comes on and then fill up to the top and pay for it, dont even look at how much it costs on the pump per litre!!:D
