Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
Seriously need a breather pipe!! Dealers say they are all on back order and hav had a look on ebay and no luck, any other places I could try as car been off the road for too long now
i also need a crankcase breather pipe and have tried the stealers with no luck either, anyone know the diameters yet? i spose i could get off my arse and go it measure myself
i agree with the silicone pipe aswell. and if worse comes to worse and you cant get a good tight fit then use heat shrink. works a treat at forming a good seal.
I just put together two bits of radiator hose, which was the similar shape and size of the orignal pipe, used a bigger bit for going to the crankcase and then put a smaller elbow shaped pipe inside it. Works a treat, will try and get a picture up
mine was perished, so took it out cut the bad piece out, the used a piece of flanged copper elbow from B&Q, and a couple o jubilee clips, works a treat..
