gazcuprablk
my 300+ death box :)
Mar 31, 2006
854
south wales
after a few days of my car leaking oil i started to search where its leakin from come to the conclusion that after changing the sump and the plug and gasket for the oil return from turbo seems its coming out of the crank seal belt side and after tryin everythin on the bolt it jus wont come off how have you lot got your bolt loose?? its killin me know as i tried a good few times earlier with the gun gettin it off and it just wont budge!
any suggestions i have looked on a few forums but not found out what is used to take it off isit a vag specialist tool or is there something else i could try??
advice/ideas welcome
anyone? gettin pissed off now it just wont budge tried everything on it heating it up with blow torch then using the air gun still no joy
sorry its the 19mm multispline bolt on the crank seal drivers side, also tried puttin it in gear my clutch is screwed so its slippin when i turn it,
also had a magic idea as i have an old pulley off my old blown motor ill weld a bar to the spare pulley and then bolt it on the engine and put the bar under the subframe so that'll lock it in place this is the only thing i can think of at the mo but seems a good idea
If you remove the inspection plug on top of the gearbox you can see the flywheel, just wedge an old bar or flat blade screwdriver in the flywheel teeth so it holds against the gearbox casing.Might be easier with 2 people.
Haynes suggests two longish steel plate bars, bolted together at one end, forming a narrow angle 'A'. The other two ends have bolts through and go into the sprocket either side of the bolt. Hold this to stop the crank turning while you undo.
Something like this
Will pm you a pic of the one I mean ;)
