couple of questions?
Jul 4, 2006
513
Maidstone,Kent
just fitted a forge 007p dv to my lcr how load is everyone elses cause i can only hear it with the windows shut, plus all i hear with the windows is like a whistling/whooshing noise is that meant to be there?
what else can i do to make my dv louder?
what induction kit should i use, my mate kier is using a bmc-cda on his is this any good?
laqcuer comin off of my brake calipers(brembo) would this be covered by warrenty?
sorry know there is alot but please help
RikH
Texas Cowboy
Oct 17, 2005
2,474
Yorkshire
description of your dv noise sounds about right
using a CAI type induction kit will enhance the noise but not necessarily make it louder, i use a green panel filter and its plenty loud enough
Mitchy
TTRS
Oct 12, 2004
2,310
BMC makes the valve quite a bit louder and you get a nice induction sucking noise.
Yes BMC is a good filter to get, expensive though at around £190.
Lacquer im afraid isn't covered under warranty, lots of people have tried and failed. It is a common problem.
CRAIGLCR
THE DADDY!!!!!
Nov 14, 2005
363
STOKE ON TRENT
I Have The Bmc-Cda Fitted To My Lcr. Expensive But Worth It!! Also The Dv You Have Is Not An Atmospheric So You Wont Hear The Noise Of A Subaru. The Noise Yours Makes Sounds About Right. And I Tried With The Peeling Laquer On The Brembos, And Got Nowhere!!!!! But The Thing Is You Dont See The Likes Of Evos With The Laquer Peeling On Their Brembos!!!
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
Yes you do! ;)
In fact, somebody posted a link to an Evo forum a little while ago that had a step-by-step guide to refurbishing your Brembos as it seems to be a common problem for them as well.
Lee M
Oh yes..........
looked at an evo 18 months old before buying the LCR. The Brembo's on there were mega tatty, pink and lacquer-less.
It had only done about 14k!!!!
