sean_c_1988
i really want corsa speedlines, they have a et 49 and 4x100 which is the same as mine, would they fit??
Yes. You will need a 12 mm spacer to get them spot on ,
There centre bore is still 57.1?
the Pcd the same?
just the offset, I uset to have a corsa so i know the offset is high not sure how high you can get away with Seats,
But to match the 37 mm offset you need a spacer!
