With
OBD11 and VCDS you can change the brightness of the reversing light (although it does not IMO make it better)
Adjusting the intensity of the reverse
With this change we can adjust the light intensity reverse.
1 - Module 09 - Electronic. Code (31347)
2 - Adaptation
3 - Select - Leuchte29RFL RA64
4 - Sub - Dimmwert AB 29
5 - Change the desired value. maximum 127
6 - Select - Leuchte28RFL LC11
7 - Sub - Dimmwert AB 28
8 - Change to the desired value. maximum 127
You can deactivate the fog lights when reversing by reversing how you activate them.
With regards to cornering lights in general (I dont have fogs but the code below shows
how to activate) you can change the min and max values to turn them off if there is no other way.
Regulation of lights or turn corner
With this modification you can change the speed at which you want them to act the cornering. By default come to 40 km / h.
2 - Adaptation
3 - Select - static curve light
4 - Sub - Untere geschwindigkeitsschwelle
6 - Sub - Obere Geschwindigkeitsschwelle
7 - Change value to 60. Default 40 Km / h
