Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
is this a common problem? my drivers side window will move about 1/2 inch then jam on its way down, it also struggles to get back up! sounds like its jamming on something! any ideas?!?
With the door card off and a little light on the subject, try operating the window. You will probably find that it will be easy to identify the problem. I had this problem with my Rover.
Sometimes the wiring can work loose and get in the way of the runners, the window will still operate but will stick.
check the cables running in and out of the motor/winder,if one part on this goes ,then bin the lot.
not expensive or difficult to replace(if you know your way around a scrappies
