Cordoba SX 2.0 16V 1999 - Engine Speed Sensor? WHERE?!
WeeJase
pert
Jun 2, 2001
8,595
goodle says it looks like this.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
tricky, but straight forward.
can't access it easily from above or below really!
jack the car up on axle stands, support the engine and remove the front engine mount.
I tend to support the engine with a block of wood with a trolley jack.
richypanic
Seat Cordoba 2.0 16v SX
Nov 8, 2008
151
Aldershot, Hampshire
Found this on GSF online shop... "92581 - CRANKSH IMPULSE SENDER - CORDOBA - £24.50" Is this the same thing as crank/engine speed sensor guys?!? The search criteria is correct for the cordy.
richypanic
Nov 8, 2008
151
Is there any possibility these work loose? Can I shimmy my hand down there and have a go? Dont fancy jacking the motor up and axle stands and all. I dont have the gear, or means to source it! Any ideas what a greasy garage would charge if I supplied the part? Cheers folks
