Coolant Sensor & misfire
wurzel
600
East Anglia
I have had an intermitent issue over the last couple of weeks when starting the car from cold that the idle seems slightly irratic and almost a misfire that clears as soon as you touch the accerlator.
This morning, same thing happened but nothing happened when I pressed the acclerator (other than more misfire and a cough) Straight away the coolant sensor light came on accompanied by 3 beeps. I switched off and restarted and problem disappeared. No other warning lights. (car smells rich when this happens but I think that is to be expected with a misfire)
I've done a search and found that cleaning the prongs on the coolant sensor may fix the coolant sensor light but would a faulty coolant sensor also cause a misfire or is the coil packs (never a problem when warm) or cold start system?
benjiwales
benji
Jan 29, 2007
297
Penybont
change the coolant sensor anyway as they fail very often and only cost £27 from vw/seat and is very easy to do. the 3 beeps is usually coolant level
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
i think the sensor in the coolant tank is only gauge related. the other temp sensor on right side of the engine on pipe is the ecu/ engine temp one.
so i dont think the sensor in the tank would cause a misfire? not sure though
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
i had problems with moisture in the maff connector. but it was more surging revs... it dried out as the engine warmed up. dielectric grease sorted it.
could be a similar thing?
wurzel
600
East Anglia
It could be the MAF as it might be mixture realted. I can only describe like a 1.1 Fiesta with a carb when starting cold.. begins to idle ok then goes a little erratic and clears with a bit of throttle (except this morning) It didn't throw up the engine management light which I would have expected.
Funkyfin2000
Black Leon Cupra R 280bhp
Oct 6, 2005
2,477
Stafford, Staffordshire
yup same as mine....it sometimes starts fine...
but othertimes its very very lumpy....i blame it on my sports cat now......but maybe not...
might need a new MAF but the values on it are fine so i can't see it being a problem, its about the only thing i havn't changed.....
its dead lumpy for about 2-3 secs then blip the throttle and its all ok..
no errors thrown up on vag.com either....
wurzel
600
East Anglia
I can't speak for VAG com errors but this sounds exactly the same as mine, except today bliping the throttle didn't have any effect - very lumpy and almost died (revs between 400 - 1100)
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
when idling does the rev counter alternate between these values? but vanishes when warm?
maf would play up at all temperatures?
either a faulty engine temp sensor (green top) or moisture on the electrics is my guess.(maf connector)
wurzel
600
East Anglia
Yes, no issues when warm or even if you switch off and start again.
The lumpy idle does sound like a misfire or wrong mixture. Without asking a numpty question where would the moisture be in the electrics?
Quick question how much will a new maf & temp sensor cost? presumably these can be DIY fit?
wurzel
600
East Anglia
Great, thanks will give that go later
Just found this on the web
"Dielectric means, effectively, an insulator. dielectric grease will not carry an electric current.
This makes it ideal for coating electrical connections that come into contact with moisture. Remember, the cennection is carried through the actual physical contact between the two terminals. The grease should be applied after the connection is made and, thus, it will not affect that contact, which is to say that it won't, in any way, increase the contact resistance of the connection. What it will do is prevent moisture and air coming into contact with the metal and it will prevent the corrosion that moisture causes. Just about any grease is good for this... Vaseline is probably as good as any other and it is a little cleaner in use." from another forum.
Maybe vaseline is worth a go?!
