Constant fault code?
grim1987
55
Wickford
Had a problem with code PO411 from the ECU as some numpty (me) fitted an external dump valve to the cupra. Now fitted the orignal bosch dump valve n had the codde removed 4 days ago.
Now the mangement light has popped up again, im just not sure what else could be wrong with the car as its the secondary air pump which has already been changed recontly, any ideas?
