Hi, am looking to amp up the 4 factory speakers on my Seat Ibiza 2009 so have just purchased a Kenwood Kac-8405 4 channel amp, shown below, to amp up a new headunit I purchased. I have run the power cable, remote power on
wires down one side, the front and rear rca jacks and 'Flatflex' speaker cables down the other side. The Amp wiring kit was the Vibe Slick 1500w kit. Have attached the amp earth wire to the seat belt bolt as well.
The Headunit I have is an Alpine CDE-136 bt headunit. It has front and rear rca cables.
What I would like to know is how do I connect into the existing speaker cable without buchering my factory speaker harness. Do I run 8 sets of cables from the amp to the wire harness at the back of the headunit and tap into them their. I have done various searches on no one seems to go into this in much detail. From what I understand I have to disconnect the speaker harness from the headunit and tap into the factory speaker harness otherwise you will have power going to the speakers from the amp and headunit and this could cause damage, is that correct?
Also the speaker wire I received in the vibe wiring kit is flat and the wire seems a bit thicker than the factory speaker cables I will be splicing into is that ok?
Your Help is greatly appreciated!!
