Right ive just added some 8.5.1 je standard bore pistons to my 1.8t engine, has rods and valvetrain done its running a gt30 at 1.8 bar when it was on standard agu pistons, now its back together and ran in its only doing 1.3 bar and feels flat above 5000 rpm checked for obvious boost leaks, timing is bang on messed with manual boost controller still no difference, im thinking its a map related problem now going to check it saturday on dyno, so my question is would the compression ratio drop cause any of these problems? p.s its running omex 600 manegment.
