Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
can i also add , that the forge FMICed car was my own car and the readings that were recorded in my car at full load in fourth gear where below wat the standard SMICed car achieved at idle parked up,
lol 90 degrees! haha
the idle temp will be higher than actual running temps as youre not running any cold fresh air over the fmic and alsothat at idle youre not shifting much air through anyway. the fmic makes a huge difference to temp figures.
i can see all of forges temps are lower , were they done on a dyno , all of ours where on road so in my opinion more believeable. still shows a massive temp drop tho
from what I've seen the Forge FMIC performs at least as well as the Cupra FMIC.
with my old ibiza pd130 (revo'd), on hot days (28+) I'd see intake temperatures in excess of 80 degrees, which would cause lots of heatsoak, and thus the ECU pulling back.
With the FMIC on, intake temperatures wouldn't go above 45...much better
kyle, to compare the pd fmic to the leon cupra one, external temps around 4.5-5 degrees (indicated) that was in 4th gear heading up the hill out of dundonald towards newtonards so quite a hefty load on the engine. id never normally hold onto 6800 and beyond tho, usually around 6k rpm.
