Common Rattles??
cus
... Vag only!
Feb 8, 2004
1,713
Middlesbrough
www.nemm.co.uk
i have loads of rattles coming from various placses, so just wondering if anyone knows of any common rattles that are easy to fix?? cheers
P.S could it be the dead body in my boot?? :confused:
Mat
i have one coming from the dash, but then i moved the air freshener elsewhere :p:lol::p lol
sorry, bad joke!
only rattle i kinda have at the mo, is from the boot panel if i turn the stereo up a bit! kinda my fault really as it never went back into place properly after de-wipering the rear window :D
Smithy
Old School
Jan 17, 2002
965
Hertfordshire
passenger airbag area for the first 2mins from cold start.
Slight rattle top left of speedo area, a slight tightening of the small screw underneath should fix.
Just turn the music up louder :)
C1TPT
256
St. Albans, hertfordshire
ive got a bootlid rattle and a rattle top left of spedo!! i also have the most annoying squeek coming from the radio but only when i go round left corners!! it goes away if i push by the heater controls lol
cus
... Vag only!
Feb 8, 2004
1,713
Middlesbrough
www.nemm.co.uk
i think everyone suffers from the boot rattle! i've took my boot plastic off. i think its coming from the locking mechanism for the key. may need some grease putting on it?
it tends to only rattle when accelerating hard in a high gear.
i'll tighten everything ican see :)
loveturbopower
187
Frome, Somerset
yep i got boot rattle aswell but i adjusted the rubber bungs where the bootlid shuts so they stick out more therefore making the boot close tighter that solved my prob, try that
ttothec
349
Reading
i had the same rattles as a few people metioned: boot rattle and top left of speedo
bootlid: i replaced all the metal clips that were bent and where the bottom of the plastic trim of the boot touches the plastic trim bodywork (if u open the boot and look directly at the bottom of the plastic trim u will probably see where its been rubbing) i used "fab foam". got it from an arts and craft shop... about 75p for an A4 sheet, self adhesive about 2mm thick foam. stuck a spall square of that where the "rub" marks were and no rattles now
speedo: undid the screw holding the plastic (underside of the visor bit over the speedo) and pulled it apart just enough to stick really thin strip of fab foam in there (cant see it as its inside). did the screws back up and no more rattles!!
there are a few really quite ones now... but i cant tell where they are coming from!! so im going to leave them :)
ttothec
349
Reading
just in front of the gear stick in the cubby hole somw where ,had it on both my cupras
i had that one too actually... took a while to find but i found mine was the lamda sensor after the cat, the wires were pushing against the heat shield and causing a squeek/rattle. pushed the heatshield on further and moved the wires slightly sorted it
cus
... Vag only!
Feb 8, 2004
1,713
Middlesbrough
www.nemm.co.uk
hey, thanks a lot for allthe replies. maybe this shouldbe a sticky???
anyways, i'll gonna try both the fixes (bootlid and speedo) and have a look behind the glove box :)
Jan 8, 2007
2,958
Wiltshire
Glad I'm not the only one suffering with these. I have the boot and top-left speedo rattles but might try people's suggestions above. Drives me mad when I've not got any music on.
ebo007
185
Dundee, Scotland
I had this too, i dismantled the radio centre console and handbreak etc, there is a bracket of some sort that attaches the centre console to the floor, i unscrewed the screw in it, threw it away and never heard it since. even when turning left.. lol. :D
Still trying to solve the boot rattle tho! :censored:
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
Yeh i get the boot lid one every now and then. My main rattle is from the stereo area. The most annoying high pitch squeal. Stops if i press just below the station numbers. Gotta get it sorted as it is slowly driving me to insanity
