colour coding engin bay.
Nev_LCR
Gone... but not forgoten
May 16, 2007
1,271
Ipswich, Suffolk
i want to give the engine bay a different look, nothin chrome or bling, i now have a red TIP,
option 1....powedercoat the charge pipe and manny red same as the car and keep the red tip. and get black boost hoses
option 2.....buy red boost hoses to go with the red tip and powdercoat the charge pipe and manny anthrasite?
or any other ideas
photshop
Faisal
UK's 1st Liquid Yello LCR
May 27, 2008
1,445
Most likely at work
id say get the red silicon hose kit,its around £100 and it replaces all the little black hoses,looks quite smart,im thinkin about it too.just got my red TIP through.
btw,is a TIP easy to install?DIY material or should i take it to a garage?
Nev_LCR
May 16, 2007
1,271
Ipswich, Suffolk
try it mate,
my saying is....if you dont try you will never learn,
its not to bad just an arse to get the old clips off.
1.9...stefan
HYBRID???
Aug 21, 2008
705
grimsby
the photoshop looks good mate, id go with something like that, looks fairly subtle
btw will be in touch this week to get myself a nevpod made up by ya-self
cheers
Ronin225
4,652
22
Worcester
most jubilee clips have a 7mm head if you dont want to buy an extended nut runner you can use a socket with an extension bar. not too big though otherwise you will overtighten it. i use a little 1/4 " drive set.
If its really awkward to get to you could put the universal joint piece in too.
I also have a TIP on order and was hoping everything was already jubileed but are those crap 1 use clips on some of the ports???
D.K
LCR 225
Oct 24, 2007
6,408
se london
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
Red pipes in the photo shop look good mate. Only thing is when i had my wheels done i asked about getting my charge pipe and inlet manifold shadow chromed so they were more black and they siad they could but it mght go a bit funny due to the heat etc
CupraMVR
Awesome GTi Technician
Oct 19, 2006
1,371
Crewe Cheshire
RED RED RED make it all go red nev looks spot on with the charge pipe and manny red i like that .
ive changed all my pipe work to red on my car i like it under the bonnet
D.K
LCR 225
Oct 24, 2007
6,408
se london
If you did do the charge pipe and manifold in red I'm sure someone would do a swap when you decide to sell up.
