Coilovers (where to buy)
luggs
Hi all,
Im interested in buying some coilovers but dont have the money to buy the best ones so i was looking to see if any of you knew where the cheapest place to get coilovers for my FR TDI 170.
help appreciated
Poverty
bear in mind that the weitecs and vmaxxs are galvanised steel whilst kw v1.2 are stainless steel.
May 25, 2008
1,919
S.Wales
www.seatcupra.net
I think its a better idea for Eibach Springs, Eibach Sportline Springs It will lower it making it look slammed on the ground but not too low and the handling better for the FR - source (sere dealer).
Oh yea not sure if your doing the fitting as well but you need to consider the labour cost and the 4 wheel tracking afterwards, can get expensive..hope this helps :)
Mar 30, 2008
621
Edinburgh
if you just want cheap coilovers, i wouldn't bother. You'll end up having ones that could potential be extremely rusty after a year, especially with the amount of salt thats thrown on the roads in winter. Plus the quality will be lower. I went for KW coilovers with inox, These are stainless steel and much better equipped at resisting corrosion. I do quite a lot of miles so i needed quality over anything else. But I would only recommend putting on lowering springs if you have not done a huge amount of miles in your car, i.e. your shocks should still be fairly fresh.
alx_chung
Dark Lord of the Torque
Sep 11, 2006
1,538
In front of a PC....
Have you had a read at this thread: Coilover Obsession Lots of really good information there. If you are not going to be tracking the car and its an everyday driver I would go for the uprated springs and/or with shocks route (I just got the Koni FSD and Eibach Pro springs fitted on mine)
Alex
Mar 30, 2008
621
Edinburgh
nice looks better, front and rear wheelarch gaps nicely balanced. i'll need to get more pics of my 35mm drop set-up. got a linea R grill now, but will also be getting 10mm spacers allround. so, i'm waiting for the spacers to go on before i post more pics :)
