Coilovers Seized
beattie17
1,353
Perth
Tried to free them off but they aint happening!
want to lower car,would it be ok to remove the little helper spring?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
closed on full droop on compression?
you may find its full droop its extended and holds the springs in some compression.
MOT fail if the springs are loose on full droop. (jacked up)
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
yes.
they crush down flat when loaded but extend on strut extension so the springs dont dislocate.
If you remove helper spring you would need to get longe rmain spring to maintain the overall length.
