Coilovers and searched
jamiebennett81
well as my wheels are going in for the refurb tomoz...Toyo T1-r's all round and then its the suspension to do
I have done a search and see people on here like the Koni's with the eibach springs, as this lowers about 15mm and still gives a good but slightly firmer ride
I will be looking at coilvers however, with adjustbale height and damping...so I can at least soften them a bit if at least too hard
I know KW Variant 2's allow for height and damping
Bilstein are just rock hard
What are Koni's like?
I know Koni do the same as the KW's with height and damping. Does anyone have experience of these at all
also from searching I think I read that adjustable drop links have to be done at the same time for some reason....?
budget is about £700 which I believe is enough
Jamie
jamiebennett81
thanks
do you know if the KW's are adjustable on the backs as well while on the car
as it says some kits are not adjustable on the backs and have to be taken off to adjust the damping?
