you're absolutely right. But I'm saying that if a bargain came up or something you might wanna buy it. That's what I did not knowing it came from the previous model. But, when I read on here that it doesn't fit, I have to inform others that thats not entirely correct.
Rear is no different. They are skinny for previous model and on ours.
Like said, front you need a different bearing (skinny one). Actually you also need different top mounts to house the bearing perfectly, which I did get but they were too small to fit the three screws where you put upper strut brace...
so I left the OEM ones and put the bearing in that. works fine, and as said no more horrible clunking like when I drove without bearing
Note though: if you're buying new then obviously opt for the right model
