Coilover clearance
Ravey_Cupra
391
Here, there and everywhere ;)
Installed my coilovers today with new top mounts and bearings on the front with new bushes on the rear...
I now have an issue with clearance between the coilover strut on the front and the inner rim/tyre of my Porsche D90 which is 8x16 ET52 and im using 25mm adaptors.
Has any experienced similar issues..if so what was the remedy?
Any advise is appreciated.
Leigh
Ravey_Cupra
391
Due to the offset and width,running bigger adaptors was going to be my last resort.
I have 30mm adaptors on the rear so I'm going to swap these with the front and hope it gives me enough clearance...fingers crossed.
ndbrgr
THFC
Jul 21, 2008
1,023
Kent
What coilovers are you running as I've got Weitecs and D90s waiting to be fitted and I'm worried about what adaptors to run.
Samoose
6j will be fine
its only due to the width of the 8s and the offsetthat they catch!
i have 8s (D90's) all round on mine and 20mm front and 30mm rear adapters but im gonna put the 30mm's on the front and get some 40mm's for the rear! :D
Ravey_Cupra
391
Sorted now...removed alot of -ve camber and have approx 5-10mm clearance between the rim/tyre and strut.
Also got myself a pair of 9" (D90's) for the rear, on my 30mm adaptors they give me 1" of poke [B)]
Will get pics up shortly.
