Coil Packs
Math
hi guys, done a long search but not really found what im looking for.
basically im going to change my spark plugs and took the engine cover off etc, now im wondering do the coipacks just lift out with a bit if a twist and pull or are the clipped in? i couldnt really see anything holding them in but the 1 i tried was very tight, before i give it a little lube up and maybe a stronger pull i wanted to make sure there wasnt a clip holding them in?
as i know these arent cheap and coil packs are pretty sensitive!
thanks,
Craig
ell0070
208
Jersey, Channel Islands
Numbers 1 and 2 will unclip and then pull out.
For 3 and 4 i think you`ll have to remove the plastic bits over the top to give you room to unclip and pull out (numbered left to right as you look)
