Hello,
Last week I had a coil pack go completely, it happened suddenly with no previous misfires or warning.
The garage I used said that they only needed to change the affected coil pack and this they did (cylinder 1). From reading this forum I fully expected the others to go shortly, the garage laughed when I turned up with three new coil packs that I purchased from the local VW dealer.
I got in the car, started it and noticed the warning light was still on so asked the mechanic to come out and clear the fault code, all was OK and I would just swap the remaining three coil packs when I got home.
Whilst we were talking the car was idling and then suddenly started mis-firing, coil pack number 4 had failed at the garage, they didn't think I was so silly buying the other coil packs then!
Anyway, all the coil packs were changed and no warning light, a day later the warning light is on and I have the following fault code:
17760 P1355 Cylinder 1 Ignition Circuit Open, static - no indication on display.
Does anyone know what this means? The new coil pack on cylinder 1 was supplied by the independent garage, the others came from VW, is the cylinder 1 coil pack faulty?
The car is an lcr btw.
Thanks in advance for any advice,
Matthew.
Matthew.
