Coil Light
dex130
56
Hi everybody,
I no this has been covered before but my problem is slights different. I get the flashing coil light which is meant to mean there is a problem however it only happens now and again. Whats everyones thoughts, sometimes after driving a bit it goes off but other times it comes on after driving a bit and its doing me nut in !!!!
DanDiesel
In my diesel is where I'll be, chugging merrily.
Mar 17, 2005
168
10
Kent
i had this exact problem back in sept 05!
it kept flashing and then it would stop and it wasn't permanent, very intermitent!
i had it booked in at the dealers alredy, when i was driving along and some very weird stuff happened!
my doors unlocked and the interior lights came on, then everything went off, dash lights, stereo, headlights, the lot! i pulled over, switched off and then it wouldn't start!
basically, it was all down to a broken wired which had originally been connected too tightly and had snapped. it stopped the alternator from working properly and charging the battery, hence the lack of power.
what was weird, was why it hadn't happened sooner? basically, as you know, the tdi engines do move about alot when revved. well this particular week i was on a fuel save and hadn't given the car any beans at all. and this was my downfall!
when the engine was revved, it moved and connected the broken wired which sparked the alternator into life.
the tdi sports have a voltmeter luckily and on start up, the volts read 12v which is wrong, it should be 14v, and after a bit of heavy revving, the volts jumped to 14v!
took Seat quite a while to find the problem as it was so tiny and obscure! i'd get it booked it straight away if i were you!
hope this is of some help, sorry bout the essay length :)
Mr Max
i cant rememember what light came up on mine, think it was the coil light, but something turnout out to be faulty with the brake pedal, get it down to your dealer & get it plugged in & checked out
