Coil Light Flashing
mattyfab
FR TDi
Jun 12, 2006
218
Barnsley
Morning Guys,
Just dropped the mrs off this morning, and as I pulled over, the coil light started flashing. Drove the short distance to work with it flashing and everything seems fine. Turned car off and re-started it, it all starts ok but its still flashing.
Ive done a search and it seems its an electrical fault. Is this restricted to the engine bay, or could it be something as trivial as a brake light etc????
Car is an 05 TDi FR
pow
84
I drove my new sport out of the garage, booted it and the light started flashing - took it back and they fitted a new brake light switch in minute - light gone :D
Ant FR
2,861
Kent
yep is usually the brake light switch, which is mad really.
However it may go off with an ecu rest. just disconnect battery for 5 mins, but maesure you have stereo code before you do it
GazGT
305
Manchester
Mine has started doing it since fitting LED Rear brake lights! I'll try reverting back to see if that sorts it.
