Clutch pedal
Gogsie78
149
Scottish Borders
Just had clutch pedal snap on me tonight!!!!!
The little welds have popped and the flap opened up, nearly sh*t myself.i was overtaking and went to change gear!!!
Had a look at the guide on the forum and i have lost the little white plastic clip, god knows where it went.
I've packed it just now and held the little flap on with mole grips for a quick fix. Does anyone have the little white clip part number?
cheers in advance folks!!!
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
All you need is the white clip mate, i had mine go about 2 weeks ago. I can post one out to you tomoz night if you wanted? As im still to collect my 3 spare ones from Seat. If not heres the part number: 1ho721357.
I was lucky and they had 1 in stock but i orderd a few spares just in case.
David.
Gogsie78
149
Scottish Borders
Thanks mate but i found the white clip after removing the head unit :)
Got the pedal welded up and put back together although clutch feels slightly different :)
Just glad it's a better weld now though!!!! bloody stupid idea.
Just out of curiosity does anyone know what the little pressure switch that the clutch pushes up is?
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Cool glad you fixed it, I think its the clutch pedel sensor or somthing like that. Does the pedelit more seem abit more 'springy' if so you`ll proberly find that the spring isnt located properly.
Gogsie78
149
Scottish Borders
Seems ok mate
Its certainly makes me a bit more secure knowing the weld is 100 times better!!!
I can't believe it was 2 little tac welds that was holding the flap, shocking design :(
