clutch pedal removal
justdidituk
does anybody know how t remove the clutch pedal on a mk3 ibiza cupra my pedal box snapped and need to remove the pedal to fix the weld just cant figure out how to get the pedal off!
help please fellow cupranet members
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
This is yet another commen fault with these cars, i think most people found it easier to weld the pedal without removing the box. I personally have no idea because mine is yet to snap.
ibiza owner
IBIZA Mk3 1.0Ltr MPi
Nasty, Hope it didn't snap whilst you were driving. My pedal box started to crack and I just caught it by placing a strong bit of metal/bracket to it in situ.
SEAT Told me that the problem is not only there is a thin bit of metal there they said it can indicate that the clutch pressure plate springs are having a problem and that more force is required to apply the clutch pedal which in the end weakens the metal and then Snap! - Mine is operated by a clutch cable but some Mk3's have hydraulic clutches I think.
You could try removing that little parcel shelf bit of plastic under the steering wheel column and the fuse cover box to the right and this might allow you to see the pedal box better but it is a pig of a place to get too isn't it.
Good luck with it.
