daz2282
dazza
Oct 13, 2006
76
ayrshire scotland
hi folks im new to this site but been reading some threads and what you's boys dont know isn't worth knowing. had to renew my clutch pedal cause the comman problem happened yes weld snapped!! but since new clutch went in theres a grinding noise comes from it sometimes as if when i press the pedal in its rubbing on something has anyone any ideas what it could be. cheers lads
Does it happen when you fully depress the clutch pedal?
I have this problem and it was caused when i had a new clutch put in. When pedal is fully depressed you hear a grinding noise. I was told it's the clutch and flywheel not mating correctly.
I either have to buy a flywheel to match the clutch i have or reduce the length of the throw of the clutch pedal by making some sort of stop
well its usually about half way in but i sprayed some wd40 up into where the pedal and the hydrolic pin links together in the foot well and it goes away for a few days then comes back
I had this, popped my head underneith the dash and saw:
hth.
JAmes
