Clutch pedal not fully springing up...
Dec 20, 2007
505
Hi guys, when i get in my car in the morning basically the clutch pedal doesnt come back up all the way..... it only seem to do it when i first start the car... the clutch is still operational but the pedal sits about an inch lower than the brake pedal, if i put my foot under the clutch and pull it back up then its fine... Clutch doesnt slip, gear changes dont crunch etc... just wandering if its anything to worry about ? :blink:
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
There a return spring on the clutch pedal? I'm not sure tbh, but worth checking. May be that its become disconnected.
Dec 20, 2007
505
Ill have a look and see if anything seems untoward underneath, if i pull it up with my foot then its fine from then on so bit of a wierd one :) ooooo ive stopped my wheels rubbing too :D
Dec 20, 2007
505
Sanded all the paint away on the lips that go under on the front wing, got the pliers out bent all the metal right back up on its self so 90degree nearly, and it hasnt rubbed since :), back hasnt rubbed either but i think its cause i removed the interior, going to put the seats back in as really they nothing certainly not as much as anticipated
helms
Console Race Car Driver
Jan 30, 2005
492
Basingstoke
yeah mine does this also, annoying really. when i put my foot back on the foot rest i just push theclutch up a bit to be sure, but seems to happen every now and then. mainly st to 2nd, but when im giving it a bit of boot, then doesnt happen...
