My girlfriend was coming off the motorway the other day and just as she was changing down from 5th to 4th gear when she put the clutch in the car slowed down rapidly (as if someone had put the handbrake on as she describes it), and smoke started coming from the steering column. The recovery guy came and said that some of the loom had caught fire under the steering column, and he then towed her to a garage for the car to be assessed by the insurance company. The insurance company said as its an electrical fault she isn’t covered and they reckon it will cost £750 to repair (although they didn’t tell us exactly what they determined was the cause or indeed what exactly needed to be repaired or replaced).
Anyway, my girlfriend cant afford £750 so I have volunteered to give it a go . I have removed the dash and this is what I found. It appears that a part of the loom (a cluster of about 20 – 30 wires) has been getting pinched by the top of the clutch pedal when the clutch cable goes through the firewall. This has either caused one of the wires to become exposed and short out on the body or the wires have just become very warm and set light to the surrounding tape. On first inspection I cannot see any bare wire so I think the latter may be the case. Also, Fuses number 1 (Engine/Engine Electronics) and 4 (Ignition Transformer) are burnt out.
The cable that is damaged runs from the big bank of connectors on the drivers side behind the fuse box, across behind the pedals and the main air channel in the centre of the dash and then disappears behind the blower unit that sits behind the glovebox. Does anyone know what this cable could be? Or even where it is likely to be entering the car? (I cant work out if its coming from behind the blower motor from the battery and then to the bank of connectors, or if it comes in by the connectors and then is running out to the fan unit).
Also, could a short circuit have caused the car to brake suddenly like it did?
Any help would really be appreciated!!!!
Thanks Guys,
Greg
Thanks Guys,
Greg
