clutch given me stick
MartIbiza
55
the clutch pedal seems to be sticking abit i mean there is play in the top but then clutch makes no noise, but when i let it spring all the way up it clicks loud when pressed down. the clutch seems to be fine and the pedal performs fine, just sticks at top bit
CraigW
Craig.
Apr 12, 2007
4,607
Hawick, Scottish Borders, Scotland
When i press down on my clutch pedal its squeaks sometimes. Coud this be something serious or just whack some wd40 on it?
Afraid to break it to you but it sounds like the start of the pedal box problem. Mine started off squeaking n i put a bit of wd40 on the clutch pedal moving joint etc and it stopped, but then a couple of weeks later the pedal box broke :confused:.
I would double check the pedal box just to make sure!
looooce
god dammit, thanks guys, ill get someone to have a look at it, i assume its under the car?
