Clutch/Gearbox problems
shaunmc263
Anybody any ideas if this would be the clutch or the gearbox
When i try to change gear sometimes it wont go into gear or it makes a crunching noise
Only way to stop this is when changing gear putting clutch right to the floor and taking it out of gear then slowly letting clutch up about 2/3cm then easing it into next gear
Going into secong gear it nearly always crunches:cry: then 3/4 are not to bad then goes into 5th very easily
happens all the time weather cold or warm engine
Dont want to drive it cause it will probably cause more damage
will get it looked at this weekend but want an idea what it may be:help:
thanks
"forgot to say its a 2001 1.4 MK3"
dolf
The Dolf
Aug 14, 2006
68
cheshire
i have a similar problem although it doesn't sound quite as bad as yours.
I am having my gearbox oil changed at the weekend which apparently may or may not help. I'll post up next week.
