buroz
Supid question... where do I top it up?
Does the clutch use the same resevoir as the brakes?
The car is a 2001 Leon 1.8T sport
Either the master cylinder or the slave is on the way out, or at least I guess there is a leak (pedal getting longer... but recovers a bit after pumping), but I need to keep it going until I can have it looked at, at the weekend (travelling a long way to work at the mo.
This is the 2nd time this has happened! Is it a common fault?
Mind you, I had the clutch pedal break (another common fault) whilst towing my race car to Spa (happened at the Dartford tunnel). I still managed to get all the way there (including a ferry crossing) without a clutch pedal... So I'm practiced at NOT having a clutch!
I love the car, but I have had some many problems with it in the 24 months of ownership (bought it with 40k miles)...
Master Cylinder leak
Front ARB bushes needed replacing
2 new CV joints (at the same time)
Clucth pedal
Indicators packed up.
Driverside window broke and fell open (on the M25, in January... -4 degrees)
is it common to have so many problems?
Clucth pedal
