i have a leon cupra on an "X" plate, ive searched the forums and found the common issues with the master cylinder.
i was driving this morning, went to change gear, and clutch pedal stayed on the floor, wouldnt even come back up when i pulled it.
i need a new clutch pedal anyway as the rod is slightly bent and the white clip is broke, is it a safe to say its the master cylinder, i didnt have no issues with the clutch upto when it failed, also how much is a pedal and master cylinder, i will be able to fit myself. thanks.
