clutch decision
Nov 2, 2004
9,335
South Wales
Whats your power goals for a start?
Be careful with those clutches, sometimes theyre just the standard LUK clutch thats had the pressure plate cover painted so you pay for nothing extra.
635
montrose scotland
ok thanks well hopefully looking @ about 250-265 bhp and roughly same torque maybe a wee bit more.so not sure what to get spoke to amd and they said a vr6 clutch with g60 flywheel would be fine but not to sure.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
MrsB lupo had a Sachs power clutch in it... G60/VR6 spec and its started to slip from only 250lbft
SPEC is what I use to very good effect.
May 2, 2006
2,758
SPEC is what you want - after seeing various clutches in various different states i wouldnt touch anything else tbh, but thats just my opinion
iv never had 1 problem since fitting my stage 3 spec :D
highly recommended for oem feel and your power goal
sachs would work with your setup also but from what iv seen, wont last too long ..
May 2, 2006
2,758
mine feels fine, just slightly different biting point on mine - not much tho
clutch feel is no heavier or lighter than it was
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
mine3 stage 3+ is as light a pedal as std
a bit more fierce on take up but not bad at all considering what its dealing with
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
Your clutch will get alot better phil. Still wont be totally oem feel as it is a paddle clutch so is more aggresive. Spec are good but not cheap. Defo get a smf though as the dmf are crap!
