Clunking Coilovers
May 25, 2004
2,691
Newport, South Wales
Think you hit the nail on the head with the spring chamfer Phil.
I just greased mine up and it has reduced the clunking for the mean time.
I only get a clunk on both sides now when on the last turn of the wheel to full lock. Before it'd do it about 4-5 times until full lock!
Can't see the greasing lasting that long though..
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
the other day from inside the engine bay i took the top part of the strut cover off (the nut and dish thingy which stops the suspension from falling out the strut!) in the hope that i could get to the bearing from there!
well i couldnt and i now realsie its a coilover off job to get to the bearing! :(
but what i did do was sprayed wd40 into the top of the strut hoping it would leak down into the bearing.
anyways it seams to have helped ever so slightly. only i can hear the EVER SO slight noise i get now which sounds more like the springs than the bearing.
if thats how the noise says id be happy (as u cant really hear it!) :yes:
but anyways, what i plan to do is, on sunday after my track day at lydon this saturday il take my alloys off to givem a good clean (brake dust/tyre debris etc) and whilst they are off il be able to get much better acces to my coilovers, so il give the springs, platforms etc a good clean with brake cleaner or sumic and then il give them a good lube with some copper grease.
hopefully that will make them perfect! :)
talking of copper grease... i have some in a tube, i assume u can get it in a spray can?! cos that would be handy, especially if it had a straw (like wd40) so i could get right up into the bearing!
or should i be using some other sort of grease/lube instead of copper grease?! :shrug:
cheers guys.
9,335
South Wales
Theres no bearing on the top mount. Its just the rubber part with the metal middle insert. The more i think of it the more i reckon its the ends of the spring being sharp and digging in and sticking.
Coilover off job this weekend coming.
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
the bearing goes in the top mount.
it sits ontop of the coilover which goes inside the top mount.
Jammy
190
I'm having this problem with the stock Cupra suspension, on a 1.4s however.
I thought it must have been the A arm bushes, but it seems to be the same problem as you are all having here, although you all talk about coilovers.
Does anyone hear it only some times? Sometimes when i'm out they dont make a sound, then they do, and recently they have been making alot of noise. Looks like i'll try what you are all trying and see how it goes.
J.
exsaxoboy!
125
sutton BRUM
I wouldnt spray wd40 on your bearings, all that will do is break down what little grease is allready there.
Copper grease is an anti seize. Its not a lubricant. You only want to use it on parts/threads you dont want to seize.
hope that helps!
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
well while i was out today i bought some white grease in a spray... seams like very good stuff, was told it was ideal to spray on coilovers and reading the tin it seams so! :yes:
i will be using this on sunday :)
this is the one i bought...
A U T O C A R E WHITE GREASE (WITH P.T.F.E)
HIGH PERFOMANCE
REPELS WATER, RESISTS HEAT AND SALT, PROTECTS AGAINST CORROSION AND PROVIDES LONG LASTING LUBRICATION.
WHITE GREASE IS IDEAL FOR USE ON BRAKE LINKAGES, COMPONENTS, GEARS, SPRINGS, BEARINGS, DOOR LATCHES, GINGES, RUBBER COMPONENTS, O-RINGS, WINDOW REGULATORS, SLIDING SHACKLES AND BATTERY TERMINALS.
got it for £4.50 trade (was £5)
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
hope that helps!
yep thanks for the info! :)
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
just to let you guys know... i sprayed my coilovers just over a month ago with the white spray grease and its done the trick! :yes:
hopefully i wont have to reapply any for the foreseeable future!
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
Mine is coming off this weekend, gonna check it all out and grease the ****er up. :D
phil... make sure you put a lot of grease in the top mount BEARING! :yes:
also grease up the sping and platforms and threads... basically grease everything bar the piston! :)
