mea02mr
Hi, have a climatronic problem which would appreciate some help with.
My car appears to heat up as normal reaching 90 on the dash board in a normal time and does not deviate from this in any sort of driving conditions.
However in the climatronic diagnostic menu, the engine coolant reading stays around 25 and because of this the climatronic system is not turning the fan on in automatic mode and i am not getting any heat from the vents.
Here is the strange bit, monitoring it whilst someone else is driving i have noticed that when turning right the coolant temp on the diagnostic menu of climatronic briefly goes up and the fan comes on and i get heat. As soon as the car is going straight again the temp drops fan slows down and i loose heat.
Any suggestions?? i have tried draining the system several times and refilling with no joy.
Does any body know where the cliimatronic gets the coolant temp from?
