Climatronic no heat
mr_mufy
Hello guys.
I need ideas to fix a ghost on my car.
Over an year i had problems with the heat, our better no heat, lool.
So i have problems with the heat unit.
- I have remove all the motor of the flaps and checked if the flaps manually works, and they are ok.
- i check all the motors and also works.
- i fell a presence of a litlle heat blow but nothing to special, i check if the houses are hot and they are, so the coolant circuit its running.
I have no isues with the A/C air works fine.
I haven't more ideias and i need help to fix the heat.
