Climate control Sync
May 1, 2021
18
Hi All,
Does anyone know how to get the dual zone climate control to stay synched? i know when there is no one in the passenger seat it goes into Eco mode on that side, which is fine, but when someone is in the car and i change the temp on the drivers side it doesnt sync. I have to go into the climate control menu and hit sync. then the next time someone is in the car...same thing again!
is this just another annoying little thing that Seat has done to make our lives a little bit more difficult?!
Steeldevil
62
12
Hi All,
You could just let the passenger decide how warm/cool they want to be.
Alsi
16
Hi All,
Keep pushed the driver’s temperature, press sync.
Deleted member 123864
As the driver, adjusting the passenger temperature should change both sides.
Not sure how. There's a sensor in the dash that senses when you press the controls. If you come from the opposite side, then it does both
Jan 17, 2024
Hi All,
Use voice command button "synchronise temperature"
