I began noticing last summer that my climate control didn't seem to be working quite as well as it used to, so the other day I got it regassed at Kwik Fit (£25!). But it doesn't seem to have made a difference.
The problem isn't that it's not blowing cold air, if you put it on the LOW setting it is freezing cold, but click up one to 18 (or whatever it is) and it feels quite warm. When I first got the car I had it on 22 almost all the time, even in the middle of summer and it felt nice and cool, but now 22 is too hot.
Any ideas? Could it be some kind of temperature sensor somewhere? No other symptoms so not sure what to check. I'm sure that previously if you went from LOW to 18 the difference was very subtle, whereas now it is very noticable. 18 is not even cold!
Cheers,
BoZ
Cheers,
BoZ
in the summer
thats quite warm, i don't have it up that high in the winter. Don't forget it should act like a termostat, so will get to a temp and hold it, sounds like yours has never worked right.
