climate control fault.
STOKOE
253
TEESSIDE
having problems with my climate control on my lcr, i have searched for this problem and it seems i have problems with a sticking/faulty temprature control flap does anybody know where this is located. or has anybody had this problem and had it fixed who could help. many thanks.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
It would help if you could describe the problem - my telepathy bump burned out years ago, working in IT support.
The temperature control flap is worked by a servomotor and levers underneath the air ducting in the central console area.
STOKOE
253
TEESSIDE
the problem is only happening every now and then, what is happening is the climate control works fine for so long then it starts blowing hot and wont blow cold even by adjusting the climate control buttons the fans adjust but still blows hot air i have to switch the climate control off to stop boiling myself.
