Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
Hi all ! anyone know why my climate control display flashed for about 5 seconds when i turned on my ignition last night ?? havent noticed this before. Any info would be much appreciated.
Hi keV64 had this happen on my beza cupra befor turned out the air con pipe had a pin hole leak from it took ages for dealer to find tho went back three times!! Lets hope not the prob for you though good luck
hi guys, thanks for the advice/replies - however i forgot to mention that this has only happened once on saturday morning and that the car is two weeks old today. The flashing only lasted about 5 seconds and cooling/ heating are working fine - so it all seems abit of mystery to me. cannot find any mention of it in the manual either ????
Mine does it i think it is has something to do with the temp setting maybe to high or to low for the cars engine to take as it would be cold on start up. i dont think its a fault m8
I think the display flashing like that means that the ECU detected that the refrigeration gas pressure is low. On such a new car I would suggest that it was not gassed correctly in the factory or that you have a slight leak, this leak could be from a stone chip in one of the aluminum AC pipes at the front of the car.
hi guys - just thought i would clear this one up ? The flashing only occurred once on a cold morning and has not happened since - my guess is that the temp was not at a level that the climate could output as it was not warm enough. I think i mentioned in my previous thread that it happened upon turning on the ignition and went off after about 5-10 secs. Am still monitoring but like i say hasnt happened since ??
