Mar 16, 2007
617
SouthWales
Hello since ive fitted my 15mm spacers onto the ibiza the rear left wheel has been clicking ? i thort it may be the arch gettin rubbed or brake pipe or even a wheel bearing but its not. Popped down to my neighbour who owns a garage in Bridgend (Local Town) and he said i mite need a new hub because one of the holes where the bolts go into the hub has worn a little at the front soo the threads have worn away. Could this be causing the clicking because one end of the spacer isnt on tightenough were the bolt isnt sealing propely?
And how much would i be looking for a new Hub roughly ?
Any advice and Help Greatfull
Thanks:p
1.4 Ibiza? drums on the rear?
Your new long bolts are hitting the internals on the brakes.
take them off immediately & inspect the internals.
Ok thanks for the advice .... Im not the most mechanical minded soo i dont reali know what im looking out for in the internals ?
thanks
look for big scrape marks from your long bolts on the brakes....
if you don't know what you're looking at, don't bother as drums are a git to put back together.
take it to a garage & get them to inspect it for damage
