Clicking and error Light
40AM
Hey, Does anyone know why I have a clicking noise from the drivers side wheel and sometimes when turning left the ! symbol lights up on the dash with a loud beeping sound.
Anyone know what it is and how to fix it?
RichN
Collecting Rings
Jan 29, 2005
533
Oxford
www.Oxford7s.net
Clicking sounds like ABS self adjustment, perhaps. Happens on mine if you pull away briskly, once per journey.
Beep sounds possibly like it could be low brake fluid level, or another braking related problem, you would have to check with vag-com but I'd personally start by checking fluid level.
40AM
I've tried vag-com and it didnt say anything about it, It only happens sometimes. but thanks for the tip
40AM
Cheers guys, I'll have to get it up on the ramps and have a look, Is it easy to fit the new abs sensor thing?
40AM
Thanks Chirs I'll have to give it a whirl on saturday cos i can see something going wrong Lol
40AM
After Checking out several things i found the brake fluid low. Once topped up the bleeping stopped and the clicking noise stopped. Hope this helps anyone else with a simialr problem
