cleaning the green filter
dash
389
surrey
May be I have asked in the wrong section earlier, is there a way we could modify the lid of the airbox so that we can change or clean the green panel filter without removing the strut brace an coil before ... everytime ...every 6 months!!! One of the stud on my suspension mount got damaged last time.
If it carries on I might have to change a suspension top mount soon....another £200 :cry:
ChrisUK
Eat My Smoke
Oct 20, 2004
2,258
Liverpool, UK
Eh ??
I just unscrew the bolts, remove the airbox lid, take out the filter, clean it & put it back in again.
Nowhere near the strut brace ??
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
It's close on my fabia, but I've always managed to squeeze the lid open enough to get the filter out, and vice versa. :)
Soon to be replaced with a BMC CDA, so not too fussed at the minute.
DIFT
Torquing all the Torque
Oct 8, 2004
1,546
Kent/London
Eh ??
Its an Ibiza mate, Sits right below (or touching) the strut brace.
I have the same problem as you... oh and my top mounts got replaced not long ago :rolleyes:
Cant see anyway of modifying the air box tbh (ive tried brut force too). Someone may have a better idea though.
dash
389
surrey
May be by moving the whole airbox forward a bit might solve the problem ...if possible. Need to find a way around this[:@]
DIFT
Oct 8, 2004
1,546
Kent/London
There is no space on a Cupra (i assume the FR is the same) to move it forward. Unless you modify the box that holds the battery.
dash
389
surrey
That would be a good idea, has anyone done anything to their battery in order to fit those cone filters?
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
Mine's bolted down in the boot. I did it to make room for other bits, but it is nice to not have to worry about battery space in the front. It means I'll be able to position by BMC to get ram air effect in the engine bay (more or less) whereas space is quite restricted with the battery in the oem spot.
