Cleaning roof lining?
Jun 29, 2001
537
Surrey
I'm worried this is a daft question (which usually means it is).
The roof lining in my car is extremely dirty on one side (drivers side). I've got some upholstery cleaner from Halfrauds which I was going to use but I'm concerned that the lining, due to being made out of cardboard, is going to sag or get damaged. The dirt itself looks like a TDI has been started up with the exhaust pointing through my window while it's been open :blink:. It looks like it needs a good scrubbing.
Am I ok to use this upholstery cleaner? Or should I be using a special type of cleaner?
Thanks in advance.
Jun 14, 2005
920
Northants.
Cleaning the rooflining is a complete pain in the ar*e!
Very difficult not to get stains or rough the surface up! - buy a new headling - about£80 from seat when I bought mine!
DC
Jun 29, 2001
537
Surrey
£80 for a bit of shaped cardboard :wtf:
I'll give it a bash with this cleaner.
If it doesn't work out, I may just live with it ;)
Thanks for the quick reply.
Jun 14, 2005
920
Northants.
I know what your saying! - but I thought that was quite reasonable and makes a hell of a difference to the interior. I'am just fussy! - and if its as bad as your describing I'd never be happy with mediocre results of cleaning! and arm ace from hours of dabbing!!
Good luck!
BMH 25
57
Midlands
i bought a miricle no wet wonder dry foam cleaning kit for £9.99. best tenner i have spent comes with all acc and gets any stains out really quickly and as it is only foam it does not soak everything, it also comes with a sponge brush for areas like a roof lining i have used it many times and it works a treat smell nice too !!!
Jun 29, 2001
537
Surrey
spray it and your pillars black :D Im actually contemplating it after someone has put two thin streaks in mine.
That's actually not a bad idea, although, it could be a pain in the butt removing everything to spray it. I have a nasty habit of breaking things.
I'll see how the cleaning goes tonight. If I make a pigs ear out of it (likely!), then this could be the something to consider.
Jun 29, 2001
537
Surrey
Sounds good. Where did you buy it from?
Jun 29, 2001
537
Surrey
Right, got stuck into this yesterday evening after work.
What a pain in the arse!!!!!! Took me 2 hours in the end. The foam is a real pig to get out once applied. I got as much out as I could but had to give up as it was getting dark.
Saying all that, the product did work quite well. It's a much prettier sight than what it used to be and there doesn't appear to be any blotches from water stains, which I was expecting. It's not perfect by any means, there's still some darker patches where the lining meets the trim, but I can certainly live with the results it gave.
Would I do it again? No!
Was it worth it? Depends how anal you are about cleaning something you rarely notice. I mean, how often do you admire your roof lining?
This was done using Halfrauds upholstery cleaner (it's not good for leather, so be careful).
So to sum up..........
I'd give it 7 out of 10 for it's cleaning ability (works very well on dirty plastic).
3 out of 10 for ease of use.
5 out of 10 for value for money (it's under a fiver and it does work)
Jun 29, 2001
537
Surrey
No mate, I didn't. I already had the Halfords stuff at home, so gave that a go. To be honest it's put me off doing it again. It's done a good enough job, though, just wasn't easy to use.
If it does get extremely dirty again, to the point where I can't live with it, I will most certainly try the stuff you've suggested :thumbup:
