Chipped Engine
noel kissane
The LCR im buying is chipped but i want the car completely original, apparently its just a matter of plugging in a laptop and switching it off (same guy that chipped it is doing this), is this the case and if so will the ecu mapping be affected? Is it possible to get some documentation stating that everything is back in normal running order??????????
Reg
Professional Detailer
Oct 10, 2005
962
Berkshire
It should be that simple, yes. Do you know who's done/doing it? Is it a big firm or backstreet bob?
Mitchy
TTRS
Oct 12, 2004
2,310
Any reason for wanting it back to standard?
Power is only there if you want it.
flashbsd
you need to know what chip it has, then i would go back to the supplier and ask for it to be removed.
225
1,836
uk
Not quite as easy as plugging in a laptop! Well unless its done by a supplier that is. You need to find out what remap its had, who did it originally and whos setting it back. As said why do you want it std? You get more power and better mpg with a remap.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
-=Rob=- said:
If you want it standard I'll swap my standard ECU for your chipped one! :cheeky:
hehehe - top idea :cartman:
i give it a week with it chipped then a week without and he'll want it back
noel kissane
It was revo'd just rang the guy now, he says its simple to switch it off. I just want an original motor thats all, after an lcr for some time, apparently only 4 brought in to this country!!!! , not in to the chipping scene.
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
Revo can be switched off by any of there dealers, I would also recommend unplugging the battery red terminal for 10 mins to clear the ECU (the ECU will adapt to Revo settings) this will reset those values...also remember you will need your PIN for your stereo after unplugging the battery
What did you mean 1 of 4 in the Country :shrug:
noel kissane
Well there was four, yes only four lcr's brought into Ireland by seat offically, my car was brought in by someone from england, so i reckon you might be tops 6 or 7 lcrs in the republic, sad i know!
