checking vac leaks on cupra via vagcom
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
no info on search on this guys
best way to check for vac leak via vagcom please
logging block 032 would be the obvious one, anyone know the values should be seeing, is this done on a run or on idle where vacuum is at its strongest?
help appreciated on this one
cheers
james walker
May 24, 2007
5,121
retford notts
Code:
Friday	5	March	2010
06A 906 032 HN		1.8L R4/5VT      01 0002
	Group A:	'032
		Lambda (add.)	Lambda (mult.)
	TIME	Self-Adaptation	Self-Adaptation
Marker	STAMP	 %	 %
	0.01	0.9	-6.3
	0.3	0.9	-6.3
	0.6	0.9	-6.3
	0.9	0.9	-6.3
	1.21	0.9	-6.3
	1.51	0.9	-6.3
	1.81	0.9	-6.3
	2.11	0.9	-6.3
	2.41	0.9	-6.3
	2.72	0.9	-6.3
	3.02	0.9	-6.3
	3.32	0.9	-6.3
	3.62	0.9	-6.3
	3.92	0.9	-6.3
	4.22	0.9	-6.3
	4.53	0.9	-6.3
	4.83	0.9	-6.3
	5.13	0.9	-6.3
	5.43	0.9	-6.3
	5.73	0.9	-6.3
	6.04	0.9	-6.3
thats what i got 032 on idle
james walker
May 24, 2007
5,121
retford notts
Code:
Group A:	'032
	Lambda (add.)	Lambda (mult.)	Bin. Bits
STAMP	 %	 %
0.25	0.9	-6.3
0.55	0.9	-6.3
0.86	0.9	-6.3
1.16	0.9	-6.3
1.46	0.9	-6.3
1.76	0.9	-6.3
2.06	0.9	-6.3
2.36	0.9	-6.3
2.66	0.9	-6.3
2.97	0.9	-6.3
3.27	0.9	-6.3
3.57	0.9	-6.3
3.88	0.9	-6.3
4.18	0.9	-6.3
4.47	0.9	-6.3
4.78	0.9	-6.3
5.08	0.9	-6.3
5.39	0.9	-6.3
5.68	0.9	-6.3
5.99	0.9	-6.3
6.29	0.9	-6.3
6.6	0.9	-6.3
6.89	0.9	-6.3
7.2	0.9	-6.3
7.5	0.9	-6.3
7.8	0.9	-6.3
8.11	0.9	-6.3
8.41	0.9	-6.3
8.71	0.9	-6.3
9.01	0.9	-6.3
logs on a power run
mrwookie
Big Daddy...
Mar 22, 2008
716
Cambs & Herts
Might be wrong but didn't think you could check for vac leaks using VAG-COM and the only real sure fire way is to pressurise the system. Like I said may be wrong though....
