Changing temp sensor
n11tht
278
under the bonnet
Hi all,
I know this may have been covered before i have searched for it but cant find any useful info.
I bought a new temp sensor to replace the old faulty one, I took out the old one swapped over the rubber o-ring and put back into place. The problem lies with the retaining clip, i cant get the sensor to go in far enough to get the clip to lock in so im leaking coolant. Ive now broken the clip [:@]. new one being ordered tomorrow.
Question is does anyone know of any useful ways to get the sensor in properly or am i maybe doing something wrong?
any help would be great as i know have to drive a clio tomorrow :(
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Twist it slight as your pushing it in, will slip in then, then clip it :D
Make sure the o ring as a bit of coolant on it, don't want it going in dry.
henryk
84
fife,scotland
Problem I had was that I thought it was clipped but it was still leaking, until I found out
that the leg of the clip on the blind side was not in it's slot.
wakko
Newbie
Jul 27, 2005
144
Blackburn, Lancashire
Make sure you remove the old o-ring. It's probably sat in the bottom of the housing which is why the new sensor won't go in far enough.
fudd
make sure the sensor is clean as well as that can effect things
