Changing Standard Speakers, Help!!
Phuture
126
hi peeps,
Have any of you changed the standard front/rear speakers in a Ibiza FR?
Looking to get an Alpine head unit (so i can use me ipod), and buy some fairly decent speakers to swap over with the standard ones.
Is this gonna be a nightmare to do?
I have searched the forums but havent found anything specifically for ibiza FR's and want to be sure of how difficult its going to be before attempting it.
Cheers :)
T. Spark
Shouldnt be too hard, the rear speakers should fit with no problems. But dependingwhat depth you go for in the front you might need to create some "custom" spacers.
I need to do this with my Alpine set up ive got, still waiting to go in!
Oct 17, 2006
2,141
Mid Wales
Changing the speakers in the FR will be no different than doing it in any other model Ibiza - just follow the info you found for the other models :)
chris04 sx
speak up & stop mumbling
Apr 23, 2007
66
Horsham, W.Sussex
Advice i can give u is take ur time as the pannels are very soft and are esy to crack. the specker are are held in by rivits. so a drill will be needed!!
and u will proberly have rattles from the rear quarter pannels after like i have!! so makes shore they are cliped in all the way around..
chris..
Deleted member 13581
I changed the speakers to Alpine ones and done it myself.
As Chris04sx says, make sure the panels are tight back on again. I missed a clip the 1st time and had rattles. Took it off and made sure they were all done and havent heard another since.
Phuture
126
cheers guys, do the panels clip off easy enough?
What alpines did u get mate, did u just use the existing wires or did u need a converter block?
pg glasgow
119
have you thought about not using rear speakers at all just fade them out and spending more on the set for the front or possibly an amp for the set in the front?
in my opinion a good set of speakers in the front and no speakers in the back is always going to give a better sound.
most of the best sounding systems ive heard just have good components in the front and a sub in the boot.depends on what your after though.
Ive got Alpine Type-s components front and rear. Alpine SPS-171A
I ran new wires in aswell.
The sound quality is great off the standard headunit. Vocals are a lot clearer.
Thinking about getting the 5 channel Alpine V-Power amp to run all components and a sub.
chris04 sx
Apr 23, 2007
66
Horsham, W.Sussex
i have an Alpine 9854 head unit, with 10'' vibe sub... the wires on the back of the head unit are universal so blocks are not needed.. i had trouble removing the standard head unit but took it to the dealer and they pulled it out for free.. i haven't changed my speakers yet but removed the panels to wire up my sub.. but will change the rear speaker some time soon.. didnt have trouble removing panels. just be careful..
