Changing Master Cylinder
tmparry01
Hi there,
Has anyone done a brake master cylinder change? Is it simple enough to do? Was access a problem? Does the mc unit just unbolt and pull out of the servo unit? ANy tips on disconnecting and re-connecting the lines on the underside of the mc?
Tom
swoosh225
Swoosh
Sep 17, 2007
501
Melton Mowbray, Leicestershire
Ive done a clutch master cylinder on a LCr which was a absolute nightmare and im a fully trained technician for landrover.As for the brake master cylinder it looks a absolute bitch theres not alot of room,Good luck:(
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
Clutch masters are easy, two pipes, two 13mm nuts and pull the whole clutch pedal box out of the car and onto the bench as one unit, swap bits over and refit. Get about half an hour to do them plus a bleed.
Brake master cylinders aint to bad, it is stright forward as it would seem. Tricky bit is bleeding them out again, certainly need a pressure bleeder. although shouldnt need to do an ABS bleed.
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
Its like many things though isnt it, it all depends how you approach it and what your used to.
Im sure doing many jobs on Land Rovers would scare the crap outta me..lol
Did you take the clutch pedal box out?
Im coming up to Melton on Tuesday evening to drop my LCR alloys off for refurb (random fact).
Steely
semiskimmed cupra R
Dec 30, 2008
1,425
Doncaster
IIRC the LC and LCR master cylinders are a pain in the arse to get out, the engines has to be shifted forwards off its mounts to actually remove and install a new one, not much space,
this is possibly my next job since a vac problem on the servo :(
